I need some help with tunercat. I have a 94 trans am that i supercharged and am running 42 lbs injectors. I am running so must fuel that it will barely run and it wont get above ~3000 rpm. It would run okay before the injector swap but it was running very lean. I have only done the very basics with tunercat, so adjusting my fuel this much is way out of my league. What do i look under and how do i change it? Also when i pulled the tune off the stock pcm, under ECM CONSTANTS it has my cylinder volume set at 0 ml/Cyl and injector flow rate at 793.46 lbs/hr. These don't sound right to me, but i am a newbie to all these tuning stuff. Any help would be awsome. I just need it to be drivable so i can get it to the place that will be tuning it. thanks
