HP
3227 Views 19 Replies 6 Participants Last post by  BrettLT1
Im rebuilding my lt1 engine. Doing a Cc306 cam, bored .30 over block, mahle forged pistions, comp cam push rods, 1.6 roller rockers, new crank and timing chain, 2800 stall convertor, electric water pump. How much hp am i looking at?
1 - 20 of 20 Posts
With all that work you should consider ported heads to aid your cam and definitely a bigger stall than a 2800 for the cc306. I've seen cc306 m6 cars make 360+rwhp. But with an auto it will be a little less
With a good set of heads 400+. I agree, you'll need more converter
With stock heads, up to 340 rw SAE. It depends on a lot of factors, one of which is the TC type/brand. Which 2800 TC are you using?
Thanks everybody fot yalls feedback. im using tci breakaway stall. and ported heads are definitly next on the list
Is this bought, or installed yet?
You'd be doing yourself a huge favor if you got rid of the TCI converter. Not only is it not enough stall rpm for the 306 cam, it's an underperforming heat-generating piece of junk. Look for a 9.5" or 10" converter in the 3200-3600 stall range. Good ones based on my own experience are Yank, Edge, Vigilante, Coan. A lot of F-body guys like Circle D also; I have no experience with them.
its bought. i talked to my mechanic and he said it will work. imma use it for now, upgrade in the future. Its a small stall but im hoping it will do good.
Work, yes.
Work well, not likely.
I would really advise returning it if you can. If you can't, just make sure to get the biggest trans cooler you can find, fit or afford.
ooh.....kay..
So, back to your original question, since I now have a better understanding of your approach, I'll say 325 hp.
We will see what we can do with it. and 325 is a low number. ive seen just cam only Cc306 motors run 360 hp to the rear wheels. and im completly upgrading everything except heads and intake manifold.
And how do you think the power gets transferred from engine to rear wheels? ;)
Like it or not, that torque converter will hurt your numbers, they all do. Automatics are not dyno queens, but the cheaper torque converters will show more slip/power loss than a more expensive unit.
Work, yes.
To add to that. Find a 4L60e from a GMT800 1500 with a tow package and take the deeper trans pan and filter combo too.
It was a $500 stall convertor
Just because you paid $500 doesn't make it "$500 converter" :(
Do the right thing, admit the mistake, send it back.
You can actually get a good converter for near $500: www.edgeracingconverters.com
Street Edge.
I can't I bought it off of a buddy. Could I use it now and upgrade a ill later when the funds get right? How hard are the to install/remove? What stall do you recommend and what brand?
wow.....some "buddy". Sorry to say you got screwed. That converter goes for less than $400 brand new :(
Sure you can use it; you can use whatever you want. It rates below the stock converter for reliability, and not much performance increase over stock. Just run a separate trans cooler to handle the extra heat. R&R involves dropping the trans.
Probably the best all-round converter for a car like yours for street and track use is the Yank SS3600, but they're in the $750-$800 range.
A good compromise for value/performance would be a 3400 Street Edge: I think they're in the $500-$550 range.
Tell me about it...and thanks buddy for your info. how much will it cost to port my heads?
.. how much will it cost to port my heads?
Here are probably your two best options if you're looking for power per dollar:
www.advancedinduction.com
and www.elliottsportworks.com
Anywhere between $900 and $1800, depending on how much you want.
1 - 20 of 20 Posts
