Hi, new to this forum. I have a 95 formula with a healthy Lt1. Upon full throttle the oil pressure goes from 60 to 30 then back up to 60 after about 2 seconds. I did not build the engine but i am assuming that it is a Meling pump as there is a sticker on the side of the oil pan. LOL Any Ideas will be appreciated.
I would download the 95 service manual at the following link. Use it to test oil pressure gauge, & it's wiring. But, sender is the usual problem. Could also be aground problem, but that would usually involve other gauges also.
And, welcome to the forum.
Thank you for the reply. & welcome. I will look into your suggestions. Honestly I'm not super concerned about it as I still am showing 30psi during that one second dip. Ive got another issue that I have been trying to chase down. That will be in another post . Thanks again!
