Hey everyone I have a 95 formula trans am lt1 auto trans it seem to idle fun but when I give it full throttle it spits and sputters really bad and loses all power it seems like its lacking power all together I have not tried anything with it yet I figured I would ask on here and try and get some suggestions if you could please help me with any suggestions that would be great thank you
Clogged cat will cause these type of problems. So will low fuel pressure. Put a fuel pressure tester on fuel rail. Do key on prime. You should have around 43 psi. Start car & idle. Pressure should be at least the mid 30's psi.
Put car on an obd 2 scanner. Read the codes. There are codes that don't light the ses. And do a running sensor scan to see what sensor data is telling you.
Download 96 service manual at the following link. It will have a whole section on driveability & emissions. My Files
