1 - 20 of 20 Posts
· Harbinger of War
ya def go with the converter best bang for your buck...its like night and day
either the sfc or the converter, a friend of mine just put a cam in is 97 LT1 and already twised the body, when you open the passenger door, it drops a good 1.5", after seeing that im looking into some sfcs
Converter
· Founder
SFC's?
I still don't have them on my car...and don't think a 4th gen really honestly needs them. Now if you've ever owned a 3rd gen you understand the need for them on those cars.
SFC's just add weight and aren't going to give you anything that puts a smile on your face. I say they can wait.
SFC's make it so we can actaully take our t tops out after a few hard launches down the track;) i know a few that waited to long and they might as well call their t top cars hardtops:p
they do help keep the car from twisting;) for 125-150bucks they do help, but they will make the car ride rough lol
for ls1's anyway i know you need them.. if you do all the bolt ons and dont have those 1-2 suspension parts, then well.. the car is gonna wrinkle up
now for the other suspension bs crap, im not a believer in.. i still have stock shocks LMAO
Chris 96 WS6 said:
SFC's?
did you read my post, not only is the door off, theres a big gap where the t-top seals at, water just pours in when it rains now
I put frame connectors the kind that come across the car in the center, and are welded to the rockers under the doors,now when I jack the car up in the front the back wheel comes off the ground.
SFC's 1st without a doubt. My buddies car (00 Z) is a hardtop also and has heads/cam/spray/TC and gears. He went to put (weld on front & rear) SFC's on the car. Left side barely lined up. right side required a 1/4-3/8 wide steel spacer at the rear due to the car being twisted from racing. If the engine is healthy (read: tons o' torque) and you drag race it it will twist into a pretzel eventually.
If you're planning on getting a cage of any sort in the next year or two, lay off on the SFC's. I don't have anything right now and my body's fine cutting 1.70 60's. Maybe the guy with the twisted body's car was in a wreck at one point?
I'd go with these mods:
1. TC
2. adj. torque arm
3. LCA's
4. gears
1 - 20 of 20 Posts
