Well I just had the intake off to do the well documented oil leak from the lifter valley and although it was a f%^*^"£%g pain it went pretty straightforward.
So feeling smug thinking most of the annoying jobs are getting sorted out up pops another one.
When the car has been on a run and for instance, you stop for fuel, the car will barely turn over. Give it a couple of minutes and it spins over fine. Its perfect from cold but it only starts this when hot. Battery and starter were new at the end of last year all wiring has checked out ok, the car is running at normal temp.
The headers are about a quarter of an inch from the starter solenoid.
I'm sure its heat soak, has anyone else had this and what did you do to cure it ie, make a heat shield, exhaust wrap , mini starter etc.
