1 - 8 of 8 Posts
Hey Guys
So today we drove to SC and where on the Road and used the cigarettelight alot, when we came home i felt warm air. I try to lacate where it comes from and found out that it is behind the shifter, right where you usualy have the little box for change, ashes of what it the world ever. It was not warm, it was hot...what could that be ?
Lars
Heat rises, the engine compartment generates a lot of heat. It will escape anywhere it can. Had C3 corvettes many years ago. They generated enough heat into the passenger compartment to keep me warm in the winter.
Hey :)
Thanks for the info, but just in case I will look into it, kinda interesting, but good to know :cool:
Yes look in there. You never know, you could have a major shorted wire or something else that could make you have a carbque.
Hey Guys
Turns out it was as simple as it could be: Not enough Power on the lighter, its fixed. Looks like somebody did something to that before and did not know what they where doing :craz28::craz28:
Hey Guys
Not enough Power on the lighter :craz28::craz28:
Huh? how did this fix your heat problem? better yet what does that even mean? Were you measuring under 12 volts? How did you fix it?
I will not use a device complete until I figure out what is going on down there, I let it charge and after that I unplugg it. I have an oilchange coming up soon and will check out more, I keep you guys informed :)
1 - 8 of 8 Posts
