96 WS6 m6 383
Alright, so after going over the entire fuel and ignition system, got my car started finally!! What a relief!.........
New problem.
I started the car, "woohoo it started!"
Went to leave about a half hour later, check engine light comes on and everything sounds "off."
Got a scanner, ran a p0336 crank sensor code, alright easy enough.
Changed the crank sensor, started it up, everything was great, no check engine light and everything sounded fine. After i shut it down and went inside for a few minutes, started it up to leave again and the same code came back and everything sounds rough again..... :craz28::craz28:
Checked the reluctor ring for movement/debris and found nothing.
So did some more checking and found that some of the wires that go to the crank sensor were resting on the exhaust and were a bit cooked, great... so today i'll be replacing those and the plug that goes to the crank sensor.
Now, if that doesn't fix it for some reason, what's next?
I was thinking about trying suicide out but we'll see lol.
pcm?
New problem.
pcm?
