I have a 97, z28, ragtop with only 35k.
For the past few months I have been trying to get it stop missing and running rich after warm up. The car starts fine and runs fine for the 1st few minutes then it starts to miss and run rich. With negative fuel trim as much as 36. And high o2 sensor waveforms .7-8. After warm up the car backfires and has sooty tail pipes. The car is pretty much bone stock with Edelbrock Shorty Headers and an SLP Loud Mouth Exhaust.
These are the things I have done:
Fuel Pressure Test 45 lb
New injectors
New Coil
New Opti Spark
New Plug Wires
Relatively new fuel pressure regulator
Ran manifold vacuum test 21lb rock solid needle
Unplugged CPS Crank Position Senor - no affect apparently only sends codes for misfires to ECU
I have run a scan tool scan toll and all the sensor are operative
Carefully looked for vacuum leaks
The issue is it starts great and once warm runs rich, misfires and backfires!
Any suggestions ?
New injectors
New Coil
New Opti Spark
New Plug Wires
Any suggestions ?
