fuel injectors
1729 Views 6 Replies 6 Participants Last post by  PA94Z
I've been building a 94 lt1 for about a year now. This is what i have so far stock block with 30,000 miles on it , ported & polished 2.02 1.60 v, aluminum heads, With .600 lunati dd lt1 springs , GMP, 1.6 roller rockers, Cc roller lifters, GMP hotcam, ported lt4 intake, 58mm throttle body, extream duty timing gear set , 1 3/4 sup,comp hooker headers , msd optispark. with a 4L60E trans that is going to the shop for a performance build for 500hp . My question is fuel injectors , i have stock 24lb injectors and know there not going to give me what im looking for for power, and have been looking for 30lb svo redtops and cant find what im looking for so hear i am . What are you guys useing. Would like to hear what you guys have to say. I've been building this engine from all lt1ls1 forum talk in the last year and think i'll have a great engine when its ready to put in my truck. thanks for any information given on the injectors.:thumbsup::thumbsup:
1 - 7 of 7 Posts
The 30 SVO's are popular and cheap. You should be able to find them on Ebay or the boards. They will be plenty for your combo. Try and buy some that are flow matched so they are as equal as possible.
I have a very similar setup and have 30# trick flows. No tb or intake upgrades.
i've always been a fan of checking duty cycle before buying the new injectors
30s are a good guess, though
svo injectors are very high quality for the price but they're a bit noisy
I went to ebay and looked at some injectors ,Are they bosch or venom? That i need, They dont say if they been flow matched ,just tested and they are used, they dont list that they are svo injectors just 30lb there is a lot of aftermarket junk also that i dont want to waste money on can i get new ones from a ford dealer ? And what year and make ford had these injectors? THANKS
I went to ebay and looked at some injectors ,Are they bosch or venom......
They are neither......they are Ford SVO's.
You can try a Ford Dealer.....but I don't think they're available anymore. You'll need to troll Ebay, Craig's List :craz28: , or check with the various Speed Shops around the country.
If you do find them used, check with speed shops local to you to see if you can get them refurbished.
Best of luck!
KW
FUEL INJECTOR CONNECTION - 30lb modified Bosch 3 fuel injector set
Here you go... I got mine from them, shipped fast.
1 - 7 of 7 Posts
