1 - 10 of 10 Posts
I have a LT1 with an aftermarket fuel pump and and a 3 port regulator. It has new stock stock fuel injectors and a in the tank fuel pump. After it started i noticed that there was fuel running out of the passenger exhaust. I pulled out the spark plugs and the # 8-cylinder plug was fouled. I replaced the injector thinking it was stuck open but the plug was fouled again. Could it be the regulator? The gauge shows 40lbs.The engine has a aftermarket wiring and the ecu has been reprogramed. It is in a older truck. There is so much fuel poring out of the exhaust i didn't let run vary long .Need help. Thanks
In order, you can: (1) Remove vacuum hose from regulator. If leaking gas, replace regulator. (2) Ensure that fuel return line to tank is unclogged. (3) Make sure plug #8 is firing when removed and held against ground. (4) Pull injectors with fuel rail, pressurize and watch for drips. Good luck -- please let us know if any of these work for you.
Discussion Starter · #4 ·
I pulled the fuel rail with the fuel injectors. I pressurized the system and sure enough the injector for the # 8 cylinder was pouring fuel out of it.Could this be a problem in the ecu?
Sounds like the ejector is stuck open. Pull the connector off #8 injector and see if the problem still exists. If you have a Noid light see if the power to the injector is pulsing.
Are you checking it with the connector off the injector? With the connector disconnected, nothing should come out of the injector. You can use a test light and see if there is power at the connector at all times. It should just pulse when the injector fires. You can check it with a known good cylinder.
1 - 10 of 10 Posts
