FS/FT: NEW 396 cid lt4 520 horse !!! NEW PRICE !!!
I bought this engine for a project that is not going to get done so i need to free up some money for others things.
$6500 for long block, manifold,injectors,throttle body. shipped anywhere in the lower 48.
I will travel a reasonable distance at no cost to the buyer up to 300 miles i am in las Vegas, NV.
i will do a partial trade on these items below.
trades im looking for
AR-10 (high end or low end)
left hand in 223 or.308 or 6.5 creedmoore
high end optics S&B, USO, PREMIER, Steiner, Kahales
or a combination of the above listed.
this is a bad ass engine for the money.
HERE ARE THE SPECIFICS ON THE ENGINE
THE BUILDER IS GOLEN HIGH PERFORMANCE ENGINES
HORSE POWER 520 @5700
TORQUE 490 @4800 not 100% on this number. but should be close.
BLOCK: LT4 4 BOLT MAIN WITH ARP MAIN STUDS
CRANKSHAFT: EAGLE 4340 FORGED STEEL
DYNAMIC BALLANCED INTERNAL FRONT AND REAR.
CONNECTING RODS: SCAT 4340 I-BEAM RODS 6”, FULL FLOATING.
PISTONS: FORGED PISTONS 11.5 COMPRESSION.
RINGS: SPEED PRO PLASMA-MOLY RINGS
ROCKERS ARMS: COMP CAMS PRO MAG ROLLER ROCKERS 1.5 INT 1.6 EXH
BEARINGS: CLEVITE H-SERIES.
CORE PLUGS: BRASS PIONEER CORE PLUGS
LIFTERS: COMP CAMS HYDRAULIC ROLLER
PUSH RODS: COMP CAMS
VALVE SPRINGS: COMP CAMS
TIMING SET: GM LT4 ROLLER
TIMING COVER: NEW FACTORY
OIL DELIVERY: MELLING HIGH VOLUME PUMP, PICK UP TUBE AND HD DRIVE.
OIL PAN: NEW FACTORY
GASKET SET: FEL PRO PERFORMANCE
HEAD BOLTS: ARP PERFORMANCE
CAM
OPERATING RANGE: 2800-6500
IDLE QUALITY: GOOD
DURATION: INTAKE- [email protected]”
EXHAUST: [email protected]”
LIFT: INTAKE .586
EXHAUST: .576
LOBE SEPERATION: 112 DEGREES
HEADS
TRICK FLOW LT4 FULL PORT
TYPE: ALUMINUM
COMBUSTION CHAMBER: 64CC
INTAKE RUNNER: 195CC
INTAKE VALVE: 2.02 SS
EXHAUST VALVE: 1.60SS
MANIFOLD
PORT MATCHED LT4, BORED TO 58MM FOR THROTTLE BODY
THROTTLE BODY: BBK TWIN 58MM THROTTLE BODY
INJECTORS: 30LB/HOUR
THIS IS A NEW CRATE MOTOR NEVER USED OR TAKEN OUT OF CRATE.
IF YOU HAVE ANY QUESTIONS I WILL ANSWER TO THE BEST OF MY KNOWLEDGE.
IF YOU WOULD LIKE DIFFERENT PICTURES PLEASE PM ME AND ILL EMAIL THEM TO YOU.
CAM
IDLE QUALITY: GOOD
LIFT: INTAKE .586
EXHAUST: .576
HEADS
TYPE: ALUMINUM
MANIFOLD
