1 - 7 of 7 Posts
SOLD!!
ERE#3 For Sale.....the B-body guys Karl Ellwein’s work quite well ;) .
This engine was recently professionally rebuilt (by Long's Machine Shop, San Antonio, Tx) due to a blown head gasket. The block, crank, pistons and rods were all inspected/cleaned. Block deck was still even but the cylinders were rehoned. Block has zero miles since rebuild.
The engine features the following:
Ohio Crank forged 4340 steel 3.75” crank (re-polished)
Eagle Forged 6.0” H-beam Rods
Mahle Flattop Pistons with -16 Valve Reliefs
Milodon Splayed 4-bolt caps
Clevite Bearings
Mahle Rings
New Stock Oil pan
New Melling M-55 HV oil pump
Custom cam installed; 228/234/110 with .611 lift on both intake and exhaust using 1.6 rockers
11.14:1 static compression ratio if you go with .030" head gaskets and 54cc heads
9.84:1 static compression ratio if you go with .035" head gaskets and 64cc heads
Of course, you can always remove the cam and use what ya want ;).
$3500 + shipped to the 'lower 48' via UPS Freight.
Thx!
KW
The engine is without heads? I have one guy in Moscow who wants to get the engine, he needs complete one. Pm me, maybe we could make the deal. Shipping will be to New Jersey.
Okay, now I see why you posted that reply on LTX.
Small world indeed :)
Good luck with the sale.
1 - 7 of 7 Posts
