21 - 39 of 39 Posts
Not directly, anyway. The ET starts when your front tires clear the staged (2nd) beam.
It could be argued that there is a connection to RT and ET with regard to staging. If you shallow stage (barely turn on the staged light), you'll have more "roll-out" before the timer starts than you would if you "deep stage" (turn off the pre-staged light but not the staged light). So, your RT would be longer with shallow staging but ET would be lower because you're moving faster with the extra roll-out by the time the timer starts.
To further make the point, there are father/son racers at the track that both run the same car, a '57 Nomad. The dad deep stages to try to get a better reaction time, while the son shallow stages. The son always dials quicker, even though they use the same shift point, stall up the same, etc., and the son out-weighs his dad by about 40 pounds (neither of them is "little"). All other things being equal, the son should be slower when he runs, but that isn't the case because of the differences in staging.
Whistles go Whoooooooooo
R/T: 1.027
60': 2.24 No Grip
1/8th mile: 8.83
MPH: 83.3
1/4th mile:N/A
MPH:N/A
M6 at 177K
Engine: LT1
Short Block: Stock
Top End: Stock
Power Adder: N/A
Rear End: Stock 10 Bolt
Exhaust: Pacesetter LTs w/ Custom 3" Y-Pipe and Magnaflow Muffler
Suspension: Stock / 6 point roll-cage
Other: MSD6AL, Accel HEI Coil, 34% Under-drive Pulley
R/T: N/A
60': 2.23 lotta spin
1/8th mile: 8.57
MPH: 89.46
1/4th mile: 12.92
MPH: 117.50
Rebuilt Corvette A4
Engine: LT1
Short Block: Stock
Top End: Stock
Power Adder: N/A
Rear End: 3.73
Exhaust: No headers, Magnaflow catback
Suspension: Far from stock
Other: 32# injectors, high flow fuel pump, Hypertech, K&N ram air, coolant bypass, vaccum bypass.
Car has 74,000 miles, Tranny has 12,000.
R/T: .71(we don't run pro tree so .500 is perfect light)
60': 1.68(tires hooked pretty good)
1/8th mile: 7.79
MPH: 87.7
1/4th mile:12.25
MPH:110.5
Engine: LT1 in 1984 trans am
Short Block: Stock
Top End: comp 501 cam, 918 springs, heads are stock with 3 angle valve job and had .015 milled off bottom and i used .026 to further bump up compression
Power Adder: N/A
Rear End: Stock 10 Bolt with stock 3.73 and posi
Exhaust: hedman long tubes custom made x into y pipe knock off 3'' muffler to 2 2 1/2 outlets
Suspension: Front tubular lower control arms, afco coil over conversion, kyb gr2 struts, Rear hotchkis springs, kyb gr2 shocks
Other: msd distributor and coil, electric water pump, 1.6 magnum roller rocker arms, bbk 52 tb, ported maf
R/T: .570
60': 1.68
1/8th mile: 7.28
MPH: 95.7
Engine: LT1 in 1996 Z28
Short Block: Stock
Top End: comp 466 cam, 941 springs, heads are stock with 3 angle valve job
Power Adder: Nano-Nitrous 75 Shot
Rear End: Stock 10 Bolt with stock 4.10s D.Locker
Exhaust: 1-7/8th Hookers, Dual 3" Cutouts
Suspension: Adj. Control Arm, Hotchkis LCAs, Panhard.
Other:That was our last decent pass on the above setup. She's been down for months while we stroke her to a 396... All forged internals... Comp Custom grind, AFR-195 heads, S60 w/5.13s.
She's almost done... so stay tuned.
Runs with scissors
Camaro
R/T: .???
60': 1.63
1/8th mile: 7.27
MPH: 95.96
Engine: 408 (stroked 6L)
Short Block: see above
Top End: Crappy ported 799 castings
Power Adder: None
Rear End: Fabbed 9", strange internals, 3.89 gears
Exhaust: 1-7/8 primary QTP
Suspension: Hotchkis springs, Bilstein shocks. Adj LCA, PHB, TA.
Other: This car is a full weight daily driver. It's gone more in it. I'll wait until it cools down then remember to adjust my pinion angle so I don't spin so bad.
G8: Don't remember all the stats, but bone stock, M6, on all season tires it ran an 8.7. The thing is very prone to wheel hop so i had to leave off idle.
Camaro
i leave off idle everytime. With my 3k stall it's the best way to leave
My latest run
60 foot 1.59
330 ft 4.86
594 ft 7.10
1/8 et 7.60
1/8mph 89.57
1/4 et 11.97
1/4mph 112.73
I just bought some more stuff for my car. Next spring i'm shootin for 11.50's
60 foot 3.59
330 ft 8.73
594 ft 11.43
1/8 et 14.67
1/8mph 45.11
1/4 et 20.38
1/4mph 65.31
Last year I was a few seconds quicker, I didn't think the air was that bad in Calgary? You guys are putting down some pretty awsome times!!! I think I might take it in for a tune-up in the spring...
Just kidding guys, it is good to see other cars to compare with. Keep the Lt1's and LS1's alive!!!
I havn't run at the track in my car yet. All stock internals with bolt-ons. Planning a build, hope to put down similiar times as you guys by spring.:LS1LT1flag:
Times
R/T: .006
60': 2.159
1/8th mile: 9.416
MPH: 81
1/4th mile: n/a
MPH: n/a
MODS:
A4 or M6 and Current Mileage:
Engine: LTI in a 93 Trans am
Short Block: none
Top End: none
Power Adder: none
Rear End: stock with 4:10 gears
Exhaust: Flowmaster
Suspension: stock
Other things worthy of mentioning:
My two LS Camaros, mods in sig, at 5800' elevation Bandimere Speedway, this past Friday.
'82 Berlinetta with 2000 LS1/4L60E (my son, who is about 60 lbs lighter than me, was driving the car that night):
60' --- 1.791
330' -- 5.299
1/8 --- 8.212
MPH -- 84.53
1000' - 10.373
1/4 --- 12.874
MPH -- 106.0
DA --- 8444'
Wind -- 2 mph head
'82 Berlinetta with 2000 SS LS1/T56 (same day, had to run skinny DOT slicks for the class that was being run that day):
60' --- 1.869
330' -- 5.473
1/8 --- 8.456
MPH -- 83.04
1000' - 11.011
1/4 --- 13.164
MPH -- 104.38 (was hitting the rev limiter - tuning issue yet to be resolved; not a problem with my "regular" slicks)
DA --- 8355'
Wind -- 5 mph head
[enter name here], " blackhawk(me), how fast is that 500+rwhp'ed turbocharged firehawk?"
me, " Not fast enough " :D
Guess I haven't updated mine.
'82 Berlinetta, ~3400 lbs going down the track, at Heartland Park Topeka last September, ran a 11.95 @ 114 mph, DA ~2000' with a 9 mph tailwind. With no wind and DA a little higher later in the weekend, was running 12.0's.
This spring, was hoping to get the '57 running in time for the season, but not there yet. Want to run a class here that requires a 12.75 or quicker ET. So, I took out the passenger and rear seats, spare tire and jack, got the weight down to 3305 lbs with about 10 gallons in the tank. Last Friday, ran a 12.61 @ 108 mph with DA of 7200'. The first race requiring the 12.75 is this coming Sunday, hope to get the gas burned down a little so the weight will be down a little more. Hope the weather/DA cooperates...
21 - 39 of 39 Posts
