ok guys I wired a couple wires (through a 30 amp fuse) to the battery, to turn the fans on. just to see if having a fan on would even fix my problem. I had a couple lose clamps and one hose with a hole in it. I fixed those did a coolent pressure test on it and pumped it to 20psi (the cap on the rad said 18) no leaks I started it up and the fans never came on, I let it get to the 3/4 mark to see if fans would come on, no...
well I have 3 questions now..
1) in shoe boxes website I think it says to use a 30 amp fuse, is that per fan, or for both fans?
2) if the fans don't keep It cool once I get them on, can I safely by pass the heater core, to test and see if that might be the problem?
3) could it be the radiator? like the coolant goes through part of it but can spread out the heat enough through he whole rad?
thanks again guys
thanks again guys
