Hey good people,I have successfully put in a new starter and radiator on my car,but now my attention has been focused on something else.I noticed the other day that I have antifreeze bleeding from around my exhaust manifold gasket on the rear driver side,I had alot of white smoke coming from the tailpipes and from the exhaust leak,also oil stick has a milky residue on it,headgasket right?,but wait there's more.The car doesn't overheat ,and the engine sounds fine,I did some reading on the forums and found that the LT1s nuts on the exhaust manifold tend to back out over a period of time so I check them,and sure as sh#t stinks they had,So I torqued them back down,So after that I started the car and the white smoke for under the hood and from the exhaust was hardly noticeble.The leak is still there but its not as bad as it was,do you think I need a new gasket or do you think its something else? And what is the triangle shape piece that's down below the manifold that that connects to the exhaust pipe on the driverside it has two screws in it,I've also notice antifreeze leaking out of it too,I wanna replace the gasket on it but I don't know what it's called. Your expertise is needed,Thanks.
