Ad #432403 Posted:2008-11-24 18:31:11
This ad expired 155 days ago.
SMALL CHEVY STROKER 396 LT1 JE EAGLE NEW FORG
$1,539.00
SWAT that Mustang or Honda Like a FLY
BRAND NEW ALL FORGED SMALL BLOCK CHEVY ROTATING ASSEMBLY
sbc stroker kit LT1
LT1 LT4 or any internal balance 1 pc rear main
actual displacement 397 ci = lots of booty kickin
64cc head at 0 deck appx 11.4:1
only 1pc rear main only 4.040 bore only flat top avail
a kit built to your needs...
NEW 4340 forged non twist crankshaft from EAGLE with a 3.875 stroke. We have run these cranks past 1200hp without failure , your choice of one piece or two piece rear seal crank, 350 mains
We are the largest eagle dealer on ebay, we are proud to sell these parts with tremendous confidence.
EAGLE 4340 h beam rods 6.00" length,
ARP 7/16" 8740 Capscrew bolts standard ( 190,000psi) unless otherwise noted. Optional ARP 2000 ( 230,000psi) and ARP L-19 ( 265,000psi) bolts for extreme horsepower applications. L-19 bolts are recommended for small block engines exceeding 700 HP and big block engines exceeding 850HP.
Silicon bronze for floating piston pins
Multi-stage heat treated.
Certified 4340 steel, vacuum degassed to remove impurities.
Each forging is X-rayed, sonic tested and magnafluxed to insure quality.
All surfaces are 100% machined.
Shot peened to stress relieve that metal.
Precision alignment sleeves positively located the rod cap, maintaining big end bore size and eliminating cap walk.
Sized and finished in USA
For pistons we are suppling JE Pro Series forged racing pistons,
Part # 181909 1.050 CH Flat TOP
� CNC machined domes with radiused valve reliefs provide optimum flame travel.
Premium 2618 Alloy
� Pin fitting and double spiro locks included.
� 990-2930-150 wall wrist pin ( 150 grams ) included.
� CNC Machined ring grooves accepts 1/16 1/16 3/16 rings ( Rings Sold Seperately )
� Optional tool pins available.
� Oil rail supports included with all pistons designed for use of rail supports
Also a set of the J E file fit racing moly rings,
KING ALECULAR PRO racing rod and main bearings.
This kit will internally balance without any problems THE PRICE IS $100.
We balance these assemblies in house on our hines balancer all the time without ever needing mallory [heavy metal].
Internal balancing is the way to go.
with a 9.00 deck this will be -.010 below deck
Buyer in the 48 states pays shipping for the kit. please call or email with questions, 702-567-3035. we accept paypal, credit cards at the shop, [by phone], or check or money order. in business for almost 9 years in las vegas, we are the real deal in speed parts.
