1 - 20 of 23 Posts
I bought a 1994 trans am about a week and a half ago it was supposed to have just been a blown head gasket. So I decided to buy it and fix it and put it back on the road in no time. Well I dropped the engine and popped the driver side head off to find water in 2-3 of the cylinders with a lot of rust . Same for the other side as well. The engine would not turn over . I have since cleaned the heads and the block they are completely level without warpage. The only problem is that the cylinder walls were rusted pretty bad and I had to sand the walls with some 240 grit in order for the pistons to be able to move enough to turn engine over. So there is one chip in the top of one of my pistons about 1/2 inch long 1mm deep and 1 mm wide . My questions are 1 do I need to replace pistons and completely rebuild . 2 why was engine so severely rusted after supposed 1 year of sitting , and 3 . Should I just put a used running motor in it and be on my way? And yes I added trans fluid to help get motor to turn over
Motor vehicle Gas Automotive wheel system Automotive exterior Automotive tire
Photograph Automotive tire Motor vehicle Rim Circle
Photograph Red Public space Wall Art
Wood Automotive lighting Red Automotive tire Gas
make sure you dont have a bent rod .on broke piston.
how many miles are on engine?
And How fat is your wallet.
and is the walls of the cylinder heavily pitted from rust.
You also might have a cracked block or head because the broke piston
Its a possibility water got in the cylinder that had compression.
Make sure theres not a bent valve on that cylinder .
get it all cleaned up
those hyper pistons are realy tough
the piston might have had to tight a ring gap swell into cylinder wall and popped the top land.
Is there realy a broke piston?
Cant tell with it full of water and oil lol
Yes there is a chipped piston, I will upload pictures tomorrow of that . As of now I have taken the oil pan off and cleaned up the pistons and cylinder walls pretty good. I will upload some bottom end pictures which everything looks to be ok and .. I am starting to think I can just end up slapping her back together .. 160,000 miles thst I know of .. unless motor was replaced at some point .. but the overall it鈥檚 looking really good now.
Motor vehicle Automotive tire Automotive fuel system Automotive exterior Bumper
Land vehicle Car Tire Automotive tire Automotive lighting
Tire Wheel Automotive tire Motor vehicle Bicycle part
Discussion Starter · #4 ·
Here is the chipped piston
here is the chipped piston
Automotive tire Automotive design Rim Bicycle part Wheel
Helmet Gas Personal protective equipment Motor vehicle Font
Discussion Starter · #6 ·
thats a scuff looks like a grinder even if it broke off it would blow it out exaust .
probably got installed that way.
Dont sweat it
head needs checked with strait edge and feeler guage
Well I put a straight edge (a level) not to see if it is level but if there were any gaps in there and there were not in any of the heads or engine block . I did go ahead and remove all the pistons and honed the cylinders lightly to get rust off . Also some of the pistons rings are stuck pretty good with rust so just cleaning that stuff up.
Automotive tire Fluid Rim Gas Vehicle brake
Automotive tire Motor vehicle Automotive engine gasket Automotive design Rim
Automotive tire Motor vehicle Automotive design Engineering Gas
Automotive tire Automotive design Rim Audio equipment Gas
Call me crazy but I like paint thinner for cleaning rust like that and a wire cup wheel on a peanut grinder lol.
Hay if you have a caliper could you measure the D exhaust ports vertical and horizontally
on cylinder heads?
Don't waste your time,buy a quality rebuilt motor from a reliable source.
I bought one of those quality rebuilds from a good source .
the oil pump got reused ,went the first week .
The bearing on bottom were new but 50,000 mile bearings the cam bearings got reused.
6000 miles They lasted
Head gaskets are nothing he never said how many miles are on it
But you never have a bad feeling when you torque head bolts in sequence with a separate person putting a dot with a marker on the head bolt as you lift off and going through the sequence 3 times with three dots
and sequence written on the head
You ever see any of those master engine builders on youtube do that like that???
Discussion Starter · #10 ·
on cylinder heads?
I am fully rebuilding even painted the block it wasn鈥檛 anything for parts .. only thing is I didn鈥檛 have any tools when I started all of this . So basically costing me a lot of money in tools that I will reuse .. I have to wait for the new piston rings to get in and can start the rebuild. Here are some pics
Tire Wheel Motor vehicle Automotive tire Tread
Yellow Metalworking hand tool Tool Wood Wrench
Automotive tire Motor vehicle Automotive design Wood Wheel
Discussion Starter · #12 ·
Nice work.,have you ever rebuilt a engine before?
Building it stock ?
did you have a caliper to measure the D exhaust ports for me.?
No I have never rebuilt one before but pretty mechanically minded when it comes to auto work. Also, no I do not have a caliper for the exhaust ports .. I could get one .. what exactly are you wanting me to measure 鈥 I need to do it because I am in the process of porting and polishing my heads .. but I have another set anyways
Discussion Starter · #14 ·
Latest update putting all back together .. getting close to finish .. I ported the heads, and got headers and Evap and air pump delete.. still undecided if I a/c delete or not .
Motor vehicle Hood Automotive design Automotive tire Automotive lighting
Wheel Tire Automotive tire Hood Motor vehicle
Automotive tire Motor vehicle Automotive design Automotive engine gasket Automotive lighting
thats the downfall of gm antifreeze but it keeps electrolices from rotting aluminum.
reverse flush it with water a bunch then back and forth a bunch youl be good
you bore it 30 over?
dang your fast
Discussion Starter · #18 ·
dang your fast
Ok so it was coolant temp sensor .. the second one because first one I bought was garbage wow! But worst thing ever is i don鈥檛 have drive or 3rd wow! This seller really did it to me
And how many miles are on it?
so youv driven it?
Dont be so fast to jump to conclusions
1st and reverse usually go first
put it on jack stands run it through gears and keep checking trans fluid
tork converter has to have filled all the way in order for clutches to work
linkage has to be right
wiring has to be right
tranny fluid cant be burnt
do your home work.
1 - 20 of 23 Posts
