Dash issues help
549 Views 0 Replies 1 Participant Last post by  garyLT1
So here's my issue just did my engine motor swap engine was a stock 93 LT with the 4l60 swapped over to a built 93 LT1with a built T56 by tick. Engine and trans where installed everything was hooked up minus emissions a/c which was deleted on the chip by PCMFORLESS. Only wiring I've done to the car is electric water pump which I installed off the 20amp smog pump spot in the fuse block, I also wired the clutch switch in due to the swap. And I wired in three auto light gauges into my interior lamp circuit so at night they turn on when I turn my lights on. Other than that that's it and this Is the issue I have. When I turn the headlight on the dash goes nuts when I turn the key on everything is normal
http://[url]http://i232.photobucket.com/albums/ee155/gcar1992/940AE7A4-B2EC-4E8F-81D9-96AE9199CBB2-3387-00000511E5EA054A.mp4[/URL]
1 - 1 of 1 Posts
1 - 1 of 1 Posts
