Another rear mount turbo thread..... it was coming anyway
lol
well i thought id get some extra thoughts on this forum since the other forums tend to get stale from time to time.
current setup
98 trans am
stock 5.7L 346ci
stock cam
LS6 intake
LS6 valley
catch can
OBX LT headers
catted ypipe
stock A4 with 3200 stall
stock 10bolt 2.73 gears
racetronix fuel pump and hotwire
301RWHP 314RWTQ 13.9 1/[email protected] mph spinning damn near the whole way on 315 sumitomos lol gonna get my kumho XS tires on and air them up for the track and not the highway and then make some passes. also gotta figure out how to launch my car withot spinning so much
HP goals for turbo build is 550ish and no more then 10psi. 14 psi will be availible but ill stick to just the 10psi spring until i get the tune right.
now for the turbo build items, ive got pretty much everything except the cam kit, base tune, and hp tuners in my garage. I can at least get it on and set up to run before i do the cam and meth kit.
INTAKE
Cone filter tucked into wheel well
3” intake into turbo
2.5” charge piping
T-bolt clamps and reinforced silicon hose couplers
31x11x3 intercooler
BOV and pipe
LS6 intake manifold
LS6 valley pan
4 port vacuum manifold
ENGINE
Stock 5.7L LS1
Tick custom rear turbo cam 226/235 .605/.610 114+2
Tick supplied valve springs
Tick supplied pushrods
LS2 timing chain
Stock Heads (317 with LS9 gasket later for 9.8CR)
Comp cams Rocker trunion upgrade
ARP crank bolt
Head studs
EXHAUST
OBX LT headers
Catless 3” ypipe with OBX resonators
Stock I-pipe
Sts style T4 header pipe with 44mm wastegate port
3” after turbo resonator
2” Wastegate dump exhaust
3” turbine exhaust
4” corsa clone tips/3” inlets
TURBO SPECIFIC
ON3 T76 w/.81 AR (.96 later)
44MM wastegate 4psi spring (10psi spring for later) (76mm/65mm)
50mm BOV
AEM water/Meth injection kit with progessive controller. gonna set on at 4-5 and full on at 10psi
TRANSMISSION
Stock 4L60E
Revmax stage 5 billet cover 3200 stall
B&M trans cooler
12+ quarts of royal purple tans fluid (lol i had to add that in there... god that was expensive)
Glowshift trans temp gauge
OIL SYSTEM
LS6 oil pump
4an feed
Summit check valve
10an drain
4psi hobb switch to piezo buzzer alert
Gear scavenger oil pump
10an return line into oil pan
PCV SYSTEM
LS6 valley pan with PCV valve
Catch can
Check valve
Vent line ran to fresh air intake tube from valve spring cover
FUEL SYSTEM
Stock fuel rails
Racetronix 225 fuel pump and harness
Aeromotive boost referenced fuel pressure regulator with 3/8 line return
60lbs siemens injector
ELECTICAL
NGK Spark Plugs BKR7E-11 5791 gapped at .032
MSD wires
Stock coils
ENGINE MANAGEMENT
Innovate MTX-L wideband
Glowshift digital boost/vac gauge
Glowshift digital fuel pressure gauge
Frost base tuned (HP tuners later)
GM 2 bar MAP sensor
GM 85mm MAF sensor
IAT sensor in MAF used, using wire adaptor.
MISC ITEMS
GM 93-97 radiator cover
Glowshift 3 gauge a-pillar pod
if anyone sees or happens to know of something im missing please let me know. im pretty sure i have everything though but no ones perfect lol
current setup
98 trans am
stock 5.7L 346ci
stock cam
LS6 intake
LS6 valley
catch can
OBX LT headers
catted ypipe
INTAKE
2.5” charge piping
31x11x3 intercooler
BOV and pipe
LS6 intake manifold
LS6 valley pan
ENGINE
Stock 5.7L LS1
LS2 timing chain
ARP crank bolt
Head studs
EXHAUST
OBX LT headers
Stock I-pipe
3” turbine exhaust
TURBO SPECIFIC
50mm BOV
TRANSMISSION
Stock 4L60E
B&M trans cooler
OIL SYSTEM
LS6 oil pump
4an feed
Summit check valve
10an drain
PCV SYSTEM
Catch can
Check valve
FUEL SYSTEM
Stock fuel rails
ELECTICAL
MSD wires
Stock coils
ENGINE MANAGEMENT
GM 2 bar MAP sensor
GM 85mm MAF sensor
MISC ITEMS
