any input :LS1LT1flag:
GM Cadillac Northstar DIS to GM HEI SBC ECM Project
Project Status: Discontinued
Project Started: Fall 2005
1. Introduction
I did not originally think of this idea but have done a great deal of research on the operation and components in the first generation 1990's (93-99) Cadillac northstar ignition setup. I have put together a lot of useful information for anyone looking to complete this project or modify the Northstar DIS setup for use on there car. These pages outline some of the needed information to run a Cadillac northstar DIS (distributorless ignition system) ignition module and coils on a SBC with almost any GM OBD-I HEI ECM \ ECU. I planed to use this on a 1227730 90-92 f-body or 1227727 90-91 C4 Y-body speed density ECM.
The Cadillac northstar first generation ignition system was used on the following vehicles:
BrandVehicleYearCADILLACALLANTE1993CADILLACDEVILLE1996 - 1999CADILLACDEVILLE CONCOURS1994 - 1999CADILLACDEVILLE DELEGANCE1997CADILLACELDORADO1994 - 1999CADILLACELDORADO ETC1998CADILLACELDORADO SPORT1993CADILLACELDORADO TOURING1993 - 1997CADILLACSEVILLE1999CADILLACSEVILLE SLS1994 - 1998CADILLACSEVILLE STS1993 - 1998OLDSMOBILEAURORA1995 - 1999
2. Cadillac Northstar DIS Theory & Operation
2.1) Overview
The Cadillac Northstar ignition system on a factory 1993-1999 Northstar engine is composed of an ignition module, four coils, a crankshaft trigger wheel, two variable reluctance crankshaft position sensors, and a cam sensor used for SFI operation by the PCM. The two crankshaft position sensors are used to quickly determine crankshaft position for fast engine starting, know as "Fast-Start". Using two crankshaft sensors allows the ignition module to determine the engine position within 180 degrees of rotation of the crankshaft. Another benefit of two crankshaft sensors is redundancy; in case one sensor fails, the module can operate off the remaining working sensors. If you are running two crank sensors and a cam sensor any one sensor can fail, including one of the crank sensors and the module will continue to operate. If you operate the module without a cam sensor both crank sensors are needed to maintain operation.
2.2) Crankshaft Trigger Wheel (reluctor ring)
The Northstar crankshaft has a trigger wheel (also called a reluctor ring) cast into the crankshaft between #3 and #4 main bearings. Two crankshaft position sensors are installed into the side of the engine block (facing front of car in FWD applications) between cylinders 4 and 6. The trigger wheel has 32 notches, 16 large raised areas, and 16 small raised areas, as seen in Figure 1 and 2 below.
Figure 1: GM drawing of Northstar trigger wheel
Image from GM, Cadillac division.
Figure 2: Cadillac Northstar crank trigger wheel put into CAD
Note: Drawing not to scale, for accurate scaled version download the the CAD or PDF drawing below.
Each notch and small raised area is 1/3 the size of the large raised area. In the GM drawing of the Northstart in Figure 1 you can see that they blacked out the notches between the small raised areas to create 24 even notches and large raised areas. This is why GM considers this a 24x trigger wheel. The eight uneven notches are used by the ignition module to determine crankshaft position to determine which cylinder is next in the firing order.
2.3) Northstar PCM & ICM wiring
Note: The firing order above is that of a GM northstar block and must be changed for SBC applications, see below
2.4) Crankshaft Position sensors
The two crankshaft position sensors used in the Northstar setup are variable reluctance sensors separated 27 degrees apart. Each sensor is mounted within a tight tolerance of the trigger wheel (reluctor wheel), 0.05" (1.3mm) on the factory engine.
2.5) Camshaft Position sensors
A camshaft position sensor is not needed on HEI ECM conversions because they are bank fire applications this is only needed for SFI PCM's.
The camshaft position sensor is positioned over a dowel pin located on the exhaust camshaft cam gear. One Off-On-Off signal pulse is created every camshaft rotation and every two crankshaft rotations.
2.6) Coils
The four coils used in the Northstar setup employ a waste spark firing method. Waste spark firing means that two spark plugs are fired at one time thus lowering the number of coils needed and the cost. When a coil fires of the two cylinders fired, one is on the compression stroke and one is on the exhaust stroke.
2.7) Ignition Control Module
The Northstar ignition control module is what processes the input from three sensors and the proper signal output to the ECM \ ECU \ PCM.
It performs the following functions and more:
- It monitors the On-Off pulses produced by the two crankshaft and one camshaft position sensors.
- It creates a 4X and 24X reference signal (4X REF HI and 24X Crank) sent to the PCM for ignition control.
- It creates a camshaft reference signal (CAM HI) sent to the PCM for fuel injection control.
- It provides a ground reference (REF LO, CAM LO) to the PCM.
- It provides a means for the PCM to control spark advance (BYPASS and IGNITION CONTROL) called IGNITION CONTROL MODE.
- It provides a limited means of controlling spark advance without PCM input called MODULE MODE.
- The IC module is not repairable. When a module is replaced the remaining components must be transferred to the new module.
2.8) Ignition Synchronization
Ignition Control Module signal descriptionSingleSignal NameVoltage RangeDescriptionACrankshaft position sensor 'A'+/- 100V ACVoltage and frequency vary with engine speedBCrankshaft position sensor 'B'+/- 100V ACVoltage and frequency vary with engine speed. Signal lags crankshaft position sensor 'A' by 27
degreesCCamshaft position sensor+/- 100V ACVoltage and frequency vary with engine speedThis signal occurs every two crankshaft revolutionsD4X Ref Hi0 - 5V DCKey on, Engine Off: Signal is high. High to low occurs at first sync, then follows firing order.EBypass0 - 5V DCKey on, Engine Off: Signal is low. Low to High occurs with PCM ignition control.FIgnition control0 - 5V DCPCM sends ignition control signal to ICM. The falling edge signals ICM to turn off coil primary
current.G24X Crank0 - 5V DCThis signal will remain high if the ICM identifies a fault with one of its three position sensortsH1/2x Cam Hi0 - 5V DCThe PCM uses this signal for sequential (SFI) fuel controlIGround Ref.0V DCThis is the ground reference between the PCM and ICM1) The crankshaft reluctor ring has 24 evenly spaced notches plus eight additional notches (shaded) used for synchronization for a total of 32 notches.
2) As the crankshaft rotates, the notches pass the position sensors and create a voltage pulse signal in the sensor that is an input for the ignition control module (ICM).
3) Because of the physical location of the 2 crankshaft position sensors, the signal of B lags the signal of A by 27 degrees of crankshaft revolution.
4) To synchronize the ignition, the ICM first counts the number of B pulses between every 2 A pulses. There can be 0, 1, or 2 B pulses between A pulses.
5) When the ICM sees 0 B pulses between A pulses , it starts counting B pulses between A pulses. When the ICM counts exactly 4, it synchronizes the ignition on the very next A pulse. If the ICM counts over 4 (jumps from 3 to 5), it waits for another B pulse between A pulse to start counting again.
6) This process allows the ignition to synchronize and fire the first spark plug within 180 degrees (1/2 engine revolution).
7) The camshaft position (CMP) sensor provides the ICM with cylinder #1 firing order information, which the PCM uses for sequential fuel injection.
8) Using 3 sensors allows the ICM to maintain ignition synchronization even if one of the 3 sensors fails.
2.9) Firing Order:
To run the northstar ignition module on a SBC you will connect the wires to the coils as follows.
1'st Gen Northstar Firing order
1-2-7-3-4-5-6-8
1'st Gen SBC Firing Order:
1-8-4-3-6-5-7-2 looking at the front of the motor counting back: driver side (right) = 1-3-5-7 pass side (left) = 2-4-6-8
2.10) Ignition Control Module Pinouts:
I have created a column in the tables below to outline which pins would be used if using the northstar ignition module on a 1227730, 1227727, or pretty much any HEI distributor OBD-I GM car.
Connector 1 - Crankshaft SensorsPinUsed on HEI ECMFunctionAYesCrankshaft sensor A high signalBYesCrankshaft sensor A low signalCNoNot UsedDNoNot UsedENoCrankshaft sensor B low signalFNoCrankshaft sensor B high signal
Connector 2 - Power and Tachometer outputPinUsed on HEI ECMFunctionAYesGroundBYesTachometer signal outputCYesIgnition controlled battery voltage
Connector 3 - Cam sensorPinUsed on HEI ECMFunctionANoCamshaft sensor high outputBNoCamshaft sensor low outputCNoNot Used
Connector 4 - PCM \ ECM OutputPinUsed on HEI ECMFunctionANo24x spark reference signalBNo1/2x cam signalCYes4x fuel control signalDYesIgnition bypassEYesIgnition controlFYesIgnition reference low
3. Trigger Wheel Design & Fabrication
3.1) Crankshaft Trigger Wheel
I purchased a used Northstar crankshaft off eBay to get the measurements of the trigger wheel and create the wheel in CAD. Here are the measurements of the Northstar trigger wheel:
Most measurements taken from the trigger wheel are giving in a range because measurements taken at different points of the wheel yielded different results, this is due to machining tolerances of the wheel. The tolerances of the wheel do not need to be very close, the notch position and size is what is important so the module can figure out where the engine is in rotation. Each of the 32 notches on the crank trigger wheel is about 15/64 (or 0.235 to be exact) of an inch in length and 3/16 - 13/64 of a inch deep. There are 16 small raised areas which are about the same length as the notches, they are about 7/32 (0.21 - 0.215) of a inch. There are 16 large raised areas which are about 3 times the length of the notches and measure in at 0.66 - 0.665 of a inch. So calculating in a percent of error for machining tolerances, each notch and small raised area are the same length. The large raised area is three times the length of the notches.
The above broken down into degrees:
- 32 notches 3.75 degrees in length
- 16 small raised areas 3.75 degrees in length
- 16 large raised areas 11.25 degrees in length
The thickness of the trigger wheel is 9/32 - 5/16 of a inch thick, the thickness is different at different points around the wheel due to the fact that one side of the wheel is un-machined cast and the other is machined flat.. The diameter of the trigger wheel is about 6 & 15/16 inches.
3.2) Northstar Crankshaft Trigger Wheel CAD
Here is the AutoCAD file of the Northstar trigger wheel, this can be scaled in size as needed:
Northstar trigger wheel (AutoCAD File)
Northstar trigger wheel (PDF File, only for viewing purposes)
Hope it works out well - GM should have used this instead
Opti was a very poor choice and put in a bad position in front of the engine and
under the water pump!
Rube Goldberg could not have done a better job of bumbling this design.
If I was installing or owned another LT1 (good engine except for the Opti)
I would convert to a multi coil design of some type.
i just don't wanna pay delteg 300+ for a bare bones kit.i was thinking it can br done cheaper with salvage parts.caddy's are a dime a dozen in my local salvage yard......
Im sure if there was a bettef, more reliable and cost effective we would have seen it by now but heres hoping you are onto something. Good luck.
