1 - 8 of 8 Posts
how do i bleed my coolant system 93 formula LT1, do i do it with it running?
and do i open all 3 valves at the same time or sepratly?
i did it with it running and it was blowing just air out the whole time til it over heated.
· Premium Member
there are only two valves.
car not running, crack them both (dont take the screws out, just loosen them several turns), add coolant slowly, and close each as a steady flow of coolant starts to come out. then start your car, pour in coolant as its running till its full, close the cap. fill your coolant res to the 'hot' line.
· Premium Member
funny, i've never seen a bleeder on the throttle body before, in all my days screwing around with lt1s.. are you sure it's a bleed screw?
either way you dont need that one
· Premium Member
it's also worth mentioning that even if you screw up the bleed screws or dont want to use them, you can just add coolant, start car, shut off car, wait, add coolant, and repeat
eventually you will get it full
the only reason for all this nonsense is that the coolant flows in reverse; so instead of pushing coolant up through the block, it's pushing it down through the head, so it has a lot of trouble evacuating air on its own.
1 - 8 of 8 Posts
