Hey Guys,
so i recently finished doing my cam and valvetrain swap, car seems to run ok idles a little high in park and in drive idle bounces a little but other than that not much issue. My concern is i drove it around for maybe a total of 5 miles since the swap, start it and let it idle here and there sometimes and decided to check the oil and it looks like it is getting some coolant. I immediately thought head gasket but have no smell no smoke and i did the combustion test and the tester fluid stayed blue. Also did a compression test and all cylinders were around the same psi. Any other possible causes before i take the motor apart once again? Other mods that have been done pertaining to anything with the coolant or radiator are trans cooler and ac/ ac condenser delete. Rad fans also will not come on if that info helps too lol
