1 - 11 of 11 Posts
I own a 1995 pontiac trans am. i want to change the 4l60e to a standard. I have two transmissions, one is a muncy 4 speed and some for three speed off a ford with a universal Chevy bell housing mount. Neither of which have bell housings. What kind of bell housing and slave cylinder do I need? Anything will help thanx!
Why do you want to take a step backwards. Using a 4 speed or trying to adapt a trans from a ford is not the answer.
That muncie 4 speed should bring you enough money to buy a six speed t-56 and the clutch, pedals, flywheel, clutch hydraulics you need.
Put your trans on craigslist or take it to an old car swap meet.
Look for a t-56 and other swap parts on craigslist.
You are probably going to have to swap rear ends also as most automatic 4th gens came with 2.73 gears. Way to tall for a manual trans.
Manual transmissions don't work well with gear ratios of 2.73 and the like. That is why the minimum gear ratio a manual comes with is 3.23 and many come with 3.42 gear ratios.
Plus if I'm not mistaken the t-56 6-speed has a steeper overdrive ratio than a 4l60e. 6th gear in 94-97 lt1 f-body is 0.50
Some 93's came with t-56 and a 2.73 rear end, but had a much lower first gear than later t-56. Must not have worked out too well as it was only offered in 93.
4l60e comes with 0.70 4th gear ratio, so going with a t-56 with say a 3.23 rear gear ratio will not hurt your top speed. 3.42 ratio wouldn't hurt much.
Besides, where can you drive 162mph?
When searching craigslist, branch out from your local area as far as your willing to drive. I know you young folks want it yesterday, but being patient will get your reward. Search craigslist everyday as people add new items everyday.
And list your muncie 4 speed in a larger city, you should be able to sell it at a good price.
Finally if you can't find what you want on craigslist, try this salvage yard search engine. You can search your state, region, or the whole country for your t-56 and related parts. These yards ship parts nation wide every day. Car-Part.com--Used Auto Parts Market
Search tempest is a search engine that makes searching craigslist much easier. Instead of having to do a separate search on every city in craigslist, search tempest lets you do 1 search and it will post up the results for all the cities in your distance range. Use the direct results mode.
Discussion Starter #10
Hey thanks guys for everything search tempest helped and the instructions you sent me helped a lot. You guys know your stuff I appreciate. I get on here later on and let you know how I made out with everything
Another quick note that you can use as a quick reference......go onto hawks third gen .com ,and look at the manual trans section for our f body's and they sell a conversion kit with all the parts needed
1 - 11 of 11 Posts
