1 - 8 of 8 Posts
This guy is selling a brand new Comp Cam Extreme Energy xe274 cam and lifter set for a small block chevy. The specs are 230/236 .490/.490 110 lobe separation. I dont know specs about cams but will this fit my 95 camaro z28? of course with the 5.7
Cams that are compatible with a vented Opti (like your '95 has) will also be rifle drilled at the front for the Opti drive.
Also, the lift is pretty low for that amount of duration. Is it a roller cam or a flat tappet?
guys im not sure on anything, thats all the guy put in the discription, he said he bought them for his 80s firebird. but he never used them, brand new in box with lifters.
......Also, the lift is pretty low for that amount of duration. Is it a roller cam or a flat tappet?
The XE-274 cam is a flat tappet cam that should NOT be installed in a LT1 engine.
It was a popular cam back in the day with the Monte Carlo SS crowd.
KW
...The XE-274 cam is a flat tappet cam that should NOT be installed in a LT1 engine...
That's what I thought. Something seemed "not right...".
Discussion Starter #8
Thanks guys! It was a good price for $180 for everything but ill just have to wait!
1 - 8 of 8 Posts
