Hey im definitately famailar with tuning especially LT1s im own a 1994 z28 and its manual 6 speed so what Im expieriencing is I for example In my main spark timing and extended timing table I specifically set every single value above 68 degrees celcius at 30 degrees timing at every map value from 20kpa to 105 kpa and my "constants" at main spark bias and minimum spark value is 0 and minimum spark value at 4000 is 10 4500 is 15 and 5000-7000 is a MINIMUM of 23 degrees of timing and so what im getting at is everything is set at 30 degrees no matter what happens and i have power enrichment set to go into power enrichment at 0% throttle position so i have all variables ruled out! using a snap-on solius scanner and used datamaster for data logging and both scanning tools read 36-39 degrees of timing WHEN IM COMMANDING 30 !!! WTF! i ask other LT1 tuners and its happens to them but other times it will actually read 30 degrees of timing so whats the thing im missing or what already built into the pcm that i cant control
P L E A S E HELP
by the way im using tuner cats and data master
THANKS!!!
P L E A S E HELP
THANKS!!!
