I'm not sure if you guys saw or not but I started this build a years back and due to other interest it was put on the back burner. I has and will run but never got finished... I decided that I wanted to change the harness to a late model(ls based ECM and harness) for the ease of tuning. I never completed the car so everything has very lil use and is in great shape. The six speed has about 5000 miles on it along with the clutch(which has not seen more than 500HP, previous build) this longblock has ~50-75 miles on it. Like I said it never got finished. Only reason I'm parting it out is to make room more other projects.
Here is the list of parts.. Prices will be added soon. Email me at [email protected] or text 580-678-6378
All parts are either new or slightly used.
Shipping will be on you unless otherwise discussed.
I will be pulling the car apart and taking pics all day monday(2-18-2013) and tuesday and taking lots of pics as I go.
Please bear with me on response times. There are lots of emails/text/PMs/ and phone calls. I will mark everything as sold when I have a buyer.
Car:
1995 Firebird/Trans Am T-top
Came factory with a 350ci LT1 & Six speed
118K miles on the body
I will part the body parts/interior when the motor, blower,trans and driveline is gone.
Factory paint that is in great shape considering miles and age.
Car is red and the interior is dark grey leather.
1998+ T/A tail lights Smoked $SOLD
Warbird fiberglass hood(red with black stripes $300
Chrome C6 wheels 18x9.5 front with (285s nitto 505s)like brand new and 18x11s 305s(Nitto drags) about 3/4 tread
wheels are perfect no rash or anything. $SOLD
Motor: 383 LT1 Engine 4.030 Block, Zero Decked,
Converted to 4 bolt mains with Billet main caps
Ohio Crank 4340 3.75 Stroke Crank 2 piece rear main (double keyed)
Ohio 4340 H beam rods
Probe Reverse dome blower pistons dish 9.0 to 1 compression
ARP Main and Head Studs
Melling HP high volume oil pump, upgraded drive
ATI BBC billet steel hub and ATI dampener
Cometic Head Gaskets
Bullet custom Blower grind Hydraulic roller Camshaft
LT4 lifters
Comp Chromemoly pushrods
Comp Guide plates
Comp Pro Magnum 1.6 roller rockers 7/16 stud
Stock casting Heads, Ferrea Valves, Inconel Exhaust Valve
Stock casting Intake hand ported/port matched
Teflon coated bearings
New GM water pump
NGK TR6 plugs
Canton Fabbed valve covers
Canton Oil pan with trap doors and kickouts
$3000
Griffin radiator with spal 10" fans
$SOLD with the fans
MSD plug wires $SOLD
MSD Billet Optispark $SOLD
Msd BTM Ignition and blaster coil $SOLD
Tremec T56
Steel flywheel
B&M ripper shifter
Spec stage 3+ clutch
$2000 with the clutch,shifter,flywheel and presure plate
1600 trans and shifter
Ford 9" rear(all podwercoated black)
Strange housing
Strange 35 spline axles
1/2"-20 x 3" studs
Stange 3.250" bearing Race Case
4.33 gears
35 Spline Detroit Locker
Aluminum pinion support
1350 Forged Yoke
Custom relocation brakets
Solid Crush sleeve
It also has welded on relocation brackets and sway bar mounts for the factory rear bar. Comes with lt1 backing plates.
Sold
C6 Front Disc brake conversion with slotted rotors and stock rear brakes
$SOLD
Impire Aluminum driveshaft Sold
Induction:
Vortech YSi Supercharger great shape not the polished one
ASP Cogdrive 50mm 80T Crank w/ ATI dampener, 26T Supercharger( have a few different pulley set-ups)
Custom YSi Supercharger Brackets
Vortech Air to water intercooler(maybe a lil small for this HP range with figured I could Use meth also)
Stainless braided lines and AN fittings for the cooling water.
Vortech bypass
3 gallon fuel cell&pump mounted in the spare tire well for cooling water to intercooler
3" piping(also powdercoated black) w/ T-Bolt clamps
Would like to sell it all together. everything $SOLD
Exhaust:
Headman stepped Headers(1 3/4"-1 7/8") ceramic coated $SOLD
Complete custom dual 3" all the way out the back
Stainless Magnaflow Mufflers
all mandrel bends(3") over the rear together
$650 OBO
Suspension:
PA red Mild steel Tubular K-member $SOLD
Spohn torque Arm w/ Driveshaft loop and crossmember Sold
Spohn Tubular rear Lower control arms $SOLD
UMI Adjustable Panhard bar $SOLD
UMI panhard bar relocation Kit $150 a must have for dual 3" exhaust
Poly Sway bar endlinks and mounts $SOLD
Factory sway bars powdercoated black $100
KYB adjustable fronts and KYB rear shocks $SOLD
Eibach Sportline 1" lowering springs $SOLD
Fuel System:
Holley Billet 58mm Throttle body $SOLD
95# ractronix fuel injectors $SOLD
Acceleronnics versafueler$SOLD
LT1 fuel rails modified with -8 AN fitting on both ends. tigged them and pressure tested! All Good. $SOLD
Aeromotive A1000 Fuel pump $SOLD
Aeromotive boost referenced regulator $SOLD
5/8" feed line,1/2" return aeroquip lines(poly stainless braid) and fittings. $SOLD
Aermotive pre-pump&postpump fuel filters $SOLD
Sumped factory fuel tank with return at the top. $200
2 Stock ECMs $70 each
Lingenfelter 100mm MAF $SPF
Interior:
Interior is completely stock/complete other than the gauge Pod and stereo.
Power window/locks
Leather seats in great shape
Removed spare tire and mounted a 3 gallon fuel cell in the for cooling water for the air to water inter-cooler. If i finished this car it would be for methanol.
All Glass in in great shape. everything works.
I am sure I missed a ton of things so don't hesitate to ask. Thanks Colt
Car:
LT4 lifters
Comp Guide plates
New GM water pump
NGK TR6 plugs
$3000
$SOLD with the fans
Tremec T56
Steel flywheel
B&M ripper shifter
Strange housing
1/2"-20 x 3" studs
4.33 gears
1350 Forged Yoke
Solid Crush sleeve
Sold
$SOLD
Induction:
Vortech bypass
Exhaust:
$650 OBO
Suspension:
Fuel System:
Interior:
Power window/locks
