Only 93 lt1 cars can jumper the pins to flash codes. 94 & 95 pcm is obd 1 and must use an obd 1 scanner to read codes.
96 & 97 pcm is obd 2 and most any newer scanner should read the codes.
You might have a aldl wiring problem. I suggest going to the following site and downloading the 94 or95 service manual, depending on 12 or 16 pin aldl. It will have aldl wiring diagram.
Make sure your aldl has battery power & grounds at the proper location. And make sure data lines tp pcm are good. I'm assuming you have obd 1 pcm & wiring in your 84.
You could also try the free scan program "scan9495" made for 93-95 lt1 f-bodies. Since you have an obd 1 f-body pcm & wiring in your car. It will read your codes, do running sensor scans.
You will need to download Microsoft dot net framework version 4.0 or newer to use scan9495 Get it at same site you get scan9495. Or go to microsoft site. Scan9495 is at
www.mediafire.com/?0elo4c935uc5s
Download newest version in lt1 v8 folder.
You will need a cable to connect car's aldl to usb port of pc based computer. Get the 12 pin or 16 pin obd 1 cable, depending on which your car has.
OBD Diagnostics
Scan9495 was written by our member GaryDoug. So any questions on program can be directed to him via PM.
