Long time no post, I've been kinda letting the car sit while I gathered money. Still not rich enough for a rebuild, but I'm working on it and had some new developments occur.
So about October last year, started having some trouble with the t56 rubbing into 4th gear. There was no noise, it was just a little stiff going into 4th. We flushed the trans fluid twice, because I accidentally added some of the wrong fluid the first time. It helped for a bit, then started up again. We discovered a leaky slave cylinder, and after repairing that, my clutch was hanging to the floor, turns out it was a bad master cylinder too. So we replaced it, and bled the clutch too, just to be sure. On the test drive after the master cylinder install, the car ran perfectly for about 10 miles, then locked itself into 4th gear. We towed it home, and there it has sat since (about mid November). Well, we've run the car about once a month or so, since it'll probably be sitting for a long time. Every other time we ran it, I tried to see if it would budge out of 4th, but no luck until about 2 weeks ago. It was warm, probably warmer than any weather we'd had since September of last year, and I didn't even intentionally test the gear. I just rested my hand on the gearshift and it popped into neutral. We ran through and tested to see what all the tranny would do, and here's what we found:
It will sit in neutral fine, and will go into 2nd with minor rubbing (no noise). It does not fully engage into first and acts like something is blocking it. It also will not let you move the gearshifter to the right in order to reach 3rd, 4th, 5th, 6th, or reverse at all. Feeling accomplished, we shut it down for the day.
A few days ago, I couldn't resist, and so we ran the car again. It was in neutral, and so I revved the engine to 2500, 3000 RPMs (foot was off the clutch). When the RPMS slowed down to idle level, you could hear some chattering noise. I put my foot on the clutch and engaged it, the chattering stopped. It did not start up again when I removed my foot from the clutch. But, as soon as I revved the engine a little bit again, the chattering started again. IDK if it is significant or not, but the weather that day was a good 10-20 degrees cooler than the day it popped into neutral.
I'm fairly sure that the 3-4 shift fork has an issue and is causing the inability to move the gearshifter, but am now confused about the chattering. That never existed before. The clutch is pretty new, about 3,000 miles on it. Any ideas on this?
