A few weeks back while driving home, my car didnt want to go into any gear any more. So i let it ride on neutral and made it home by a few feet. So, the next day i checked the aster slave, & it had no pressure. So, i bled the slave, & put it back on. Still wouldnt go into gear, so i did it again & found shaving. So, i just decided to change the clutch. Finally i get the chance to do it today. Everything goes well, i took the transmission off easily. Then, changed the clutch, & put the transmission back on. Finally, i "adjusted" the clutch fork. To me it set it with the click. So, i thought it was fine.
Finally my brother tells me to put the slave back on. ( which worked fine) Then he tells me to pump it, but i tell him not till were finished. Till he washed my head & i did it. So, i pumped it 2 times slowly, & for the 3rd one the slave snapped & the clutch fork got stuck all the way to the bottom. Like going toward the engine. After, we go under and take out the slave & try to pop out the clutch fork. But it was/is super stuck. So we take off all the bolts again, & tried to take out the transmission. But the transmission didnt move at all.
Finally, i gave up. The tranny didnt come loose at all. ( yes all the bolts were/are off) I dont know what to do or how to take it out.
