since many people are unsure of how to use it or wat it is here is a quick right up on it..
first u need to test if ur car needs to be clayed. u can do this by feeling the surface of ur car with saran wrap on ur fingers if it slides across smooth and feels like glass u probably dont need to clay bar but if its rough and dirty then u can clay it . clay is good cause it will get rid of tough things in ur paint that reguallry hand washing wont do. like bugs tar ect...
1.) make sure ur car is washed and cleaned very well and avoid sunlight
2.) avoid sunlight and make sure the part ur cleaning isnt to hot from the sun
3.) make sure u use plenty of clay lubricant while ur doin the application cause u dont want the clay to dry. (lubricant- any kind of quick detailer or u can buy the acualy lubricant specifically for that)
4.) after spraying the area use medium pressure and rub the clay back and fourth
5.) the surface should feel a lot smoother than the ones you have yet to reach
6.) then dry the surface with a microfiber cloth and buff to a nice shine. rember its the same concept as waxing work in small areas to make sure u get it all
if i missed anything let me know i hope this helps
