I have Tuner CATS tuner program which I just got and I am totally new to PCM programing and I am looking for help with the following.
I am going to change my Injectors from 27# to Ford SVO 42#. What do I have to do to correct my PCM for the new Injectors.
Is it as simple as changing the Constant, if thatis so do I just put in 42# or is there some other calculation that has to be used such as fuel pressure.
What motor is this for, and why are you jumping all the way to 42's??? Question being, is it warranted??? That's a lot of fuel capability there.
http://www.audiohelix.com/file go here for a spreadsheet that will calculate the numbers for you. I haven't used CATS so I don't know how it sets up for different injectors. LT1/LS1 edit uses a constant value, HP tuners makes you use the variables,(more precise and time consuming.)
Discussion Starter · #4 ·
383 LT 550hp, It had 27# injectors and 65psi fuel pressure when I got it and was running way rich with the small injectors.
