hi guys I just took everything off to do a opti swap.. since I have the water pump off I changed the water pump drive seal and opti seal now im jw bc my opti was filled with coolant the gaskets were pretty shitty installed on the waterpump from whoever was in there last.. so im trying to think if the waterpump failed or if the gaskets were just bad.. the waterpump is out of the car now is there anyway I can test it? to see if it leaks threw the weep hole?.. or I can just do the weep hole mod and start the engine but if I only have to take the waterpump out once that would be great!!!
