hey guys like the title says whats the best place to get stock lt1 aluminum heads ported and what price could i be looking at. the car will be used as a street car with occasional drag strip visits
I would say once you get past bolt ons then head porting work would be a good option. Most people go with cams first and most cam only builds put out around 350rwhp but if paired with heads they could reach closer to 400+ depending on how aggressive the cam is and what not.Ok, since the subject is head porting, at what point do you think it is
prudent to get the cyl. heads ported ? I guess saying it another way, at what point in the realm of H.P output would it be best to have your stock heads ported? ed
already been tuned on current set up and i want more i am by far not the best street car around hereCan I have some of this money you're wasting? I could use it. If you want the best street car get a dyno tune and call it a day.
Many swear by Advanced Induction.hey guys like the title says whats the best place to get stock lt1 aluminum heads ported and what price could i be looking at. the car will be used as a street car with occasional drag strip visits
havent looked into them guess i'll do that later today and try to make a choiceMany swear by Advanced Induction.
Porting shifts the powerband to a higher rpm range and I suggest performance ring and pinion gears to take advantage of the higher rpm power band along with headers and good exhaust of course a good flowing intake and throttle body.
a couple other sources 1st offers various stages of porting and the areas they work on.
For a street car the stage 1 or stage 2 might be what you want
Cylinder Head Porting Prices | Johnson's-Quality-Machine.com
For a hot performance build and best value Lloyd Elliots
http://elliottsportworks.com/
If your racing and want to set some records
Advanced Induction Cylinder Head Development
Total Engine Airflow TEA CNC Porting Aluminum Cylinder Heads Custom Assemblies | :: Total Engine Airflow ::
Port & Polish Services/Stages - 3 angle performance valve job, We specialize in LS1 aluminum intakes, LT1 aluminum intakes, Mustang 5.0 Upper & Lowers, Dual Plane Intakes, Single Plane Intakes, Small Block & Big Block Cylinder Heads. Mopar, Che
http://www.smithbergracing.com/
Reher Morrison Racing Engines
