I
imported_admin
·Guest
Need a tq arm that moves the mount off the trans tailshaft.
BMR or Spohn? I'm leaning to the Spohn because its bolt-in.
What I like about the Spohn other than the bolt in factor is the driveshaft loop and the fact the crossbar dips to clear the Y pipe, as mine hangs pretty low under there.CamTom12 said:Spohn is a high-quality piece, Chris. Its the one I'm getting with my 12-bolt and I'd suggest it to you. Fit very much
good on my buddy's car.
That's the price to pay. With a non-daily driver its much less of an issue. THe poly trans mount already added quite a bit of vibration.CamTom12 said:oh, Chris...
You're going to get a lot more vibrations/road noise with it mounted to the chassis, just so you know :evil4:
Thank you, Clearance is good depending on what exhaust is being ran. The Kooks system and stock will have no issues seeing then can run our straight cross member.gettinthere said:That's a nice looking piece Ryan. How is the clearence on it?
There might be some slight grinding on the rear for the 9", This I have not had the chance to try yet to be honest. It will bolt up to 12-bolts just fine. As soon as I know the answer I will post it, I am sure to try it out soon.GriffZ28350 said:i was probably going to go with the umi when i get one. i got some lca's from them and they are excellent quality. any clue how that may fit with a 9 inch ryan? i know there is some fab invloved with getting a spohn or a bmr to fit, so i assume its the same with yours. weather there is or isnt ill still be buying from umi when its time.
UMI Performance said:Thank you, Clearance is good depending on what exhaust is being ran. The Kooks system and stock will have no issues seeing then can run our straight cross member.
I do no that not everybody is running the Kooks set-up and hardly any still using the stock y-pipe so you would then have to go with our drop down design. On a lowered car there may be some slight scrapping, on a stock height car there should be no issues. We built the drop down cross member to fit as tight as possible yet still have appropriate y-pipe clearance. The drop down cross brace will even clear with the TSP y-pipe.
you guys need a car for test fit?? lol. ill also be in the market for some upper and lower a-arms soon, so you'll be hearing from me.UMI Performance said:There might be some slight grinding on the rear for the 9", This I have not had the chance to try yet to be honest. It will bolt up to 12-bolts just fine. As soon as I know the answer I will post it, I am sure to try it out soon.
I apprecaite the business and we will be sure to treat you right.
Regards,
Ryan
