ive swapped rocker arms and pushrods with identical oem parts and had the same issue
with a 5/8 deepwell socket and a rachet. tighten em down till the rods stop spinning, 3/4 of a turn after that.How are you tightening the rocker arms
Are you tightening each lifter when it is on the base circle of the cam?with a 5/8 deepwell socket and a rachet. tighten em down till the rods stop spinning, 3/4 of a turn after that.
How could a chain slip?im doing everything to the t of the haynes repair manual. would the dots still line up if at somepoint the crank managed to slip 180 degrees on the chain?
If you cannot verify TDC using the crank pulley arrow, then either find TDC manually, or just adjust each lifter one by one.i didnt install it. i believe its the original. 120k+ on the motor. i took the cover off and noticed the hub had slipped from what i thought was tdc. went to readjust the the valves and this was the issue.
