I have killed two alternators in the past week running 6600 rpm +. Before the cam swap, I never went over 6000 stock bottom end. Is this a function of the alternators burning out from the revs or do I have another electrical problem?
Still running the stocker.LiquidFire350 said:what brands are you guys using
same herenostyta said:Still running the stocker.
is this the return of bad luck racingbaddogz28 said:I murdered another one yesterday... Got a free battery at the same time I picked up my latest alternator because it tested bad as well. After a couple blasts on the highway, the volts gauge was back in the red. I'll pick up another one tomorrow.
99formulam6 said:why are you revving so high anyway? is limiter set that high, or is that where you shift?
