1 - 1 of 1 Posts
Heavy-duty air hose reels are spring loaded for automatic rewind. A locking ratchet holds hose at the desired length. Adjustable guide arm can be angled to compensate for the mount location. Mounting base has two 1/2" wide slots and two 1/2" drilled holes for easy mounting to a suitable flat surface such as floor, ceiling, or wall. 3/8" hose with 1/4"NPT end is included.
25' hose reel - $64.99
http://cs3automotive.com/index.php?a=PROD:1190
50' hose reel - $95.99
http://cs3automotive.com/index.php?a=PROD:1191
Air Hose Kit (Reel To Air Supply) - $22.99
http://cs3automotive.com/index.php?a=PROD:1192
Air Hose Kit includes three feet of 3/8" hose and two 3/8"NPT fittings to connect air hose reel to air supply. Hose may be cut to desired length before fittings are installed.
1 - 1 of 1 Posts
