my rear hatch sticks out about a 1/2 inch or so. I see the brackets at the very top of the hatch. is there a special way to unscrew the hatch to adjust it? I can barely fit anything in there to loosen the bolts let alone slide the hatch up a bit.
The real hatch has 2 sets of brackets holding it on. The first set is on the hatch itself. Then there's a set of brackets holding the hatch assembly to the body. They will be covered by a plastic trim panel on the rear most part of the roof, inside the car.
Both sets of brackets should have some adjustment available by loosening the nuts and sliding the hatch.
I have good luck adjusting the hatch by closing it with nuts loose. Then I climb in the car and tighten the bolts with hatch closed with the hatch in the position I want.
