I just want to make sure i'm not gonna have to re-do another head gasket job -- it's a real pain in the butt!
The thermostatic switch idea is good, and I could splice it easily enough. I'm looking for billet tanks right now to prevent my overflow from bursting in the future.
well if you dont want to blow a head gasket, you shouldnt really care about cooling the car while its NOT running.
you should be focusing on:
having a good water pump working as it should
having no water leaks
having your water system clean "no deposits or corrosion etc"
having a radiator and hoses in good shape.
getting a lower temperature thermostat.
having your fans working properly and having them tuned to a lower starting point.
having your system bleed properly "air free"
using the right coolant or either water wetter
an over heated engine does not only occur by fan failure, it can also be caused by poor lubrication, excessive rpm range for a long time, water sistem clogged, corrosion in water paths inside your engine, drain plugs destroyed from the inside....
takes a lot more than just a simple switch to turn on the fans while your car is not running.
think about this:
if you are using your car, it gets to working temperatures, the fans kick on, they eventually should stop once the desired low engine temperature is reached, so it start climbing up again and fans kick in again.
if you park your car and your fans are not working it means that the car is still in a minimum operating temperature... why in the world would you want to lower this temperatures while the engine is not WORKING?
you are basically chugging tylenol and you dont even have a headache, just to prevent one.. which is not good for your liver "in this case your battery"
I do know that engine temperature rises a little once you turn off the car, but dont think this temperature reaches 230°F.... it does rises in the first 5 min a couple of degrees 3 to 8 degrees at the most!!!!, but nothing to blow a head gasket..
go ahead and do your mod, im not telling dont do it, but it just seems that your heading out in a wrong path to prevent a blown head gasket....
commonly head gaskets blow in operating engine conditions, not while its off, the do blow sometimes if you are quite dumb to get cold fresh water into your engine while its not and you have your engine off.
but what the hell, go for it!
by the way, overflow tanks are designed to overflow and release pressure so hoses dont blow up..... read a little more before
http://www.custompistols.com/cars/articles/overflow.htm
