1 - 14 of 14 Posts
I replaced my 3 channel rear end on my 94 TA with a 4 channel out of a 99 Z28, question I have searched and searched to no avail but is there any way to fool the computer into thinking the ABS system is ok so the light won't come on? I've had Mustangs that I removed the EGR components on and put a Diode in the line that canceled the Check Engine light and thought something like this might do the same on the ABS.
Thanks for looking.
· 10 Second Opti Club
No, you can't do anything like that as far as I know. You may be able to unplug the EBCM and I think the light stays off. Your car currently has non functioning abs and will continue that way until you install a 3 channel rear, just making sure you are aware.
Discussion Starter · #5 ·
I think 93-97 had the 3 channel which didn't have Traction Control with the ABS reluctor ring on the ring gear and the 98 up was a 4 channel with or without Traction Control but the reluctor ring was on the axles. I hope I'm right any ways !
· Whistles go Whoooooooooo
Nope.
My 1995 came OEM with a 4 chan rear, if you opted for the traction control option, you got a 4 chan rear.
Discussion Starter · #8 ·
I think the non-ABS will be ok being I drive it about 50 miles per year.
Thanks
Discussion Starter · #10 ·
I'd actually like it off if possible without to much expense. If it's not possible or to costly I have the old 3 channel that was in it and I'll just build it 4:10 with a new carrier and put it back in.
Thanks
I took my bulbs out. I drive with no abs quite often.
So my question is, is the 3 channel and 4 channel a year related thing, and if so, what years used what? Or is it a having traction control or not having traction control thing.
I'm not sure if the actual reluctor rings are different or if the systems themselves are different with regards to sensors or the wave pattern produced. Never really cared much about abs!
Discussion Starter · #14 ·
Me either I always liked to lock my brakes, it don't seem like the brakes are working if they don't lock.
1 - 14 of 14 Posts
