Hi, I'm looking for 1 of the 2 bolts/nuts that mount the headlight assembly in the front end sheet metal. This is a T30 bolt that goes thru a plastic bushing and tightens with a 10 mm nut. I just need 1 bolt and 1 nut.
Is this something you might have available? These 2 bolts is what each side headlamp assembly pivots up & down.
Thanks in advance
Ron
I'd go online to McMaster Carr website. They have about any type of bolt you can imagine. Also, your local hardware store may have what you need. The best thing would be to take the other bolt with you to get diameter & thread pitch.
