The previous owner put the fans on directly when you turn the ignition on... where I live it tends to get pretty hot outside, on top of that I have a ground effects kit but installed the aftermarket air dam... the thing is I want to know if the fans are on high or are they on low directly... they dont sound too loud as if they were on high and if I drive for more than 30 minutes with the A/C on it goes past 235.. any help is much appreciated, also I ordered the 160 hypertech t-stat, radiator is new, and water pump is good also.. thanks
