Just want to be sure when I put my opti in I "know" which hole to put the cam pin in on the cloverleaf. My question is does the opti center shaft have to go in a certain way like the splined drive, or does it just go in for balance ect in no particular way Im assuming there will not be a flat spot like the pre 96 optis. Im guessing in wont matter I just need to line up the cam dowell pin correctly.. I looked on Robs sh box couldnt find anything about it on the 96 and later optis. most likely just a common sense thing just want to be sure Tommy Thanks in advance
If you'll go back to showbox site, and look at # 54 in the component views section, it shows back of 95-97 pin drive opti. Pic shows where cam dowel pin should go. www.shbox.com
Know that people have stuffed the cam dowel pin into the shallow clover leaf indentations by mistake.
