Hi there!
My name is LT1_duke and I am new to this forum! I have a life-time project here that I am restoring: its a 85 Camaro that I want to put a 1996 LT1 engine with a TH700 into! The car has received a new paint job and is ready for the engine installation. The engine is a LT1 Corvette engine with aluminium heads!
I have a centrifugal supercharger here that is mounted on the LT1 engine:
photos.app.goo.gl
photos.app.goo.gl
My goal is to produce around 400 horsepower. The stock LT1 has 300 horsepower. So I need about 6-8 PSI of boost.
I would like to run the Optispark as the distributor, but get rid of the issues with respect to the timing pick-up - and simply use the existing 4x cranksensor to time injection and spark. This is possible with the 411 PCM/ECU modification:
Few questions I have here:
1) I have the HPtuner software here and that can be used to program the 411 PCM/ECU. Do you know if I am able to put a boost-retard in there? I would like to reduce timing by 1 degree per PSI of boost, so in total 8 degrees retard for 8PSI of boost. Can I do that with the 411 and HP tuners?
2) I would like to run a MSD ignition system on the engine. This should not be an issue with the converted 411 module as any potential spark-over in the optispark will only damage the timing circuit board which I am not actually using. With the 411 PCM/EDU modification, the damage-prone part of the Optispark is not required to function. Has anyone done this and is this possible?
There is also the option to use the "MSD Boost Timing Master" in conjunction to a MSD 6 series ignition unit, but I would rather go without this box as it is 500 dollars extra...
www.holley.com
What do you think?
New item by Stefan Pace
MSD 8762 Boost Timing Master for use with MSD Ignition Control
The Boost Timing Masters allow you to adjust the amount of ignition retard from 1° per pound of boost to 3° per pound via a control knob that you mount on the dashboard. This way you can make adjustments on the fly to prevent detonation as fuel quality or altitude and air quality changes up to a...
What do you think?
