I have a 1995 caprice wagon with the 5.7.. the cooling fans turn on when I start my wagon and don’t turn off unless I turn off my wagon. what could be causing this issue? I changed the sensor on the water pump and I’m still having the same issue. thanks for your help
Discussion Starter · #2 ·
update: I have replaced the thermostat and checked relays and I am still having the same issue. Could it be the sender? where is the sender located? and would a bad sender trip the check engine light?
