When u turn the car to the on position you hear the fuel pump go on then off? Not. Sure what all the cleaning entailed... Maybe unplugged injector or two, or plugged in wrong
Jimmi, Did you touch anything at all on the car, when you got home you just shut it off and went inside??? As long as you are being straight with us,then I would call the garage and let them know the situation. Someone from the shop may be familiar with this and just come out and do the repair in yourPlease help. My 95 Z28 wont start...just cranks. I had a new fuel filter and fuel system cleaning done yesterday. Now the car wont start at all. could these guys have forgotten to connect something?
As far as I am aware,I believe there is only one wire that is attached to the opti distributor and that is the opti wiring harness. If thats the caseThanks for all of the suggestions guys. I was able to get it running long enough to take it back to them this morning (died 5 times on the way). They looked at it, and said it had good fuel pressure. Then, while checking wires and hoses while car was running, the mechanic moved a wire going to the opti and the car died instantly. Repeated with same results. They said the contacts were dirty and wire wasnt firmly connected. They cleaned contacts and replaced wire. Car seems to be running fine now. I'll keep my fingers crossed. Thanks for all your help.
