I’m installing 95 corvette lt1 with an 700r4 trans
I need help figuring out where all the radiator hose will connect. Pictures of you have any. And all wire connection.
Sent from my iPhone using Tapatalk
If you would go to the following link, you can download the 4th gen firebird parts book. It should have exploded views of coolant hoses. Also 95 firebird service manual to help you.. I believe only difference bettween vwtt lt1 & firebird lt1 is, 1 of the fittings on vette water pump is a little different than firebird.
My Files
Also shoebox site has coolant hose diagrams also. shbox.com.
If you run into problems with hose routing, you should be able to use a firebird, or camaro lt1 water pump. I'm betting wp is tired and could use replacing. Not to mention new seals on timing cover.
Service manual will have wiring diagrams. If you need corvette wiring diagrams, get them at www.bbbind.com
