95 Camaro 3.4 V6 Eletrical Issues everywhere.
1556 Views 1 Reply 2 Participants Last post by  cocobolo95
Hi!, Ive got a 95 Camaro. Ive visited this site a tons of times and usually find the answers I am looking for, but this time no luck.
Here is my Delimma, My dome lights dont work at all. there is no dinging sound when the door is open and the keys are left in it. the Cig lighter dosent work, the radio will show the clock display but as soon as you turn off the car it resets the time. the radio its self dosent work. The heater is blowing out cold air, the power seats will go forward but wont go back. and my keyless entry no longer works. the horn will work my dash lights work, headlights work, and car is now saying its over heating. but since its like 30 degrees outside and I was driving on the freeway I dont believe what the thermostat is saying. Im not a mechanic but I am pretty handy. The car does have an after market CD player added into it with the factory one still there. All these problems just happend about a month ago the rest of the 4 years I have had the car there hasent been issues.
so Please help.
I suggest you go to BBB Industries- Premium Alternators, Starters, Power Steering Products and get your 95's wiring diagrams. You can also download the 94 factory service manual in the 4th gen section. The 94 shares about 98% of it's info with your 95. The manual, in volume 2, has a full set of wiring diagrams, trouble shooting help, a driveability and emissions section also.
I'm afraid your going to have to dig into those wiring diagrams. You start with checking that all fuseable links are good. Then it's on to the electrical part of the ignition switch, it's attached to steering column under dash, to see if all inputs and out puts have got battery voltage. The ign sw feeds all power to the ignition controlled fuses. Next on to both fuse boxes to see if appropriate fuses have power to your systems. Then you will need to check out what each fuse feeds and make sure all the power feeds and grounds are good.
The only symptom you have that I can say what it is, is the radio loosing the correct time when you shut ignition switch off. Radio has 2 power sources 1st is for the radio itself. It is usually ign controlled. The 2nd power source is for the memory. It is always hooked to a live power feed, not ignition controlled. Without the live memory power, you loose the clock and radio presets every time you turn ign off.
