I have a 94 LT1 out of a chevy caprice interceptor with a painless harness installed. I pulled the engine and put it into a rat rod project I've been working on. While the engine was out I replaced the spark plugs, wires, coil, icm, optispark, and the fuel injectors. The air pump was also removed. The car starts up great but after running for maybe 10 - 15 seconds it will start to pop and backfire slightly out of the exhaust at idle. When it does it misses slightly. For the life of me I can't figure out what is going on. I double checked all of the vacuum lines and could not find any vacuum leaks. I also triple checked the wires to make sure they were in the correct order. The injectors were replaced with some off brand Most Plus 24lb injectors.
Any help or input would be greatly appreciated. This was a gift to my father and a project for us to work on. I really want to get this on the road so he can drive it to work and show it off.
Link to a video of the popping / backfire: 20210221_170410.mp4
Thanks in advance!
Thanks in advance!
